MikeMcC
- Aug 28, 2007
- 0
- Age
- 39
Gentlemen,
I recently started loosing coolant and fouling the plugs on two cylinders in my 99 4.0L 4x4 Ranger . The truck would also run rough and smoke a bit at startup. With the help of a friend and these forums we determined that this was a bad head gasket or a cracked head.
I just finished pulling the heads and dropping them off at the machine shop for milling and a valve job, however in the meantime I would like to clean the injectors while they are out of the truck.
The only problem I'm having is seperating the fuel injection supply manifold from the lower intake. I have removed the bolts that are suppose to hold it in place but it just won't budge. I still have the fuel rail attached but I have disconnected the fuel line. I think the two parts are just held together by the old gasket. Is there something I can spray that will help loosen it all up?
Thanks!
Thanks!
