shadow88
- Sep 7, 2011
- 0
- CLOQUET MN
- FORD
- Engine Size
- 4.0
Changed the o2 sensor today and it made no difference, it started hard also
Welcome Visitor! Please take a few seconds and Register for our forum. Even if you don't want to post, you can still 'Like' and react to posts.
I would pull the codes and see what the computer is thinking is wrong. It may save you lots of time.Changed the o2 sensor today and it made no difference, it started hard also
That empty port....vacuum modulator from the auto trans thats no longer there?It ran fine in the donor, I have one vacuum port that I don't have any thing for, and it had something when it was in the donor, I just plugged it for now, ive gone thee this thing a hundred times and can't figure it out, according to the diagram on the donor I got everything, but it had something to it,
You need to fix these.Year: 1990
Make: FORD
Model: BRONCO II 4X4 m5od
Engine: 2.9<--- 4.0l
Class: 4X4
Used For: dd
90 BII 2.9 M50D, 3:73 gears, exploder buckets, D35,(soon to come, explorer leaf springs and a 4.0)
Rich means: too much fuel or not enough air.Ran codes engine running, getting code 177 HEGO indicates system always rich, this explains why it's choking out, so it's not getting enough air? Or it's getting to much?
