4.0 transmission fluid idea
JoeOh
I had to use a long plastic hose to take out some ATF out of my truck because it was a bit overfilled. I was thinking that I do need to change my ATF fluid but my truck has not had a ATF change in over 150k miles apparently. So I talked to a mechanic and he said it would be best to leave the fluid alone becuase there are so many miles on the truck (256,000 miles) and the ATF has not been changed ever since I got the truck.
So I was wanting to see if I could do a slow change of the fluid by taking 1/2 a liter out of the transmission by way of that plastic hose and do it once a week until the fluid taken out is relatively clear of cloudiness and a nice red color.
Anyone else did this? Since my truck does not have a drain plug for the tranny, this is the only way I can think of doing this.
I do want to try to see if this is ok to do because I know that oxidized ATF fluid doesn't properly lubricate the transmission as well as new fluid.
Thanx-
exbass94
39
Guilford, CT
4.0 SOHC, 4.0 OHV
Just drop the pan, change the filter, and refill it. New fluid does not kill transmissions, old crappy fluid does. The only time new fluid will hurt a transmission is if it is already slipping and almost dead. If it still works fine, then changing the fluid is the best thing you can do to maintain it.
Psychopete
29
FW, IN
+1
There will be some material on the bottom of the pan as well - there's a magnet for this purpose, clean that out. Definitely change the filter. I believe the A4LD in my '88 had a drain for the torque converter under the inspection dust plate if you even wanted to get more out. Be sure to follow specific instructions for this as the pan bolts can be over tightened.
Pete
JoeOh
Do 6 cylinder 4.0 Liter '96 Rangers torque converters have a drain plug? I would like to get that drained too. Also if I get most of the fluid out of the TC and the main tranny would that be 4 quarts for my truck???
irishblessing
Guest
i didnt have a drain plug for my torque converter i pulled the pan drained the fluid replaced the filter and its 4 quarts to fill it back up and youll need a gasket too
bergz0
8
nj
leveling kit
31x10.50x15
plus adding a some LUCAS transmission treatment to it wont hurt it. put it in mine when i changed the filter and gasket and it works fine, runs smooth.
Sasquatch_Ryda
Forum Staff - Retired
108
Terrace, BC, Canada
Solid Axle Swap 4x4
40s
If its working fine, just drop the pan and replace the filter and gasket and top it back off.
No need for any cover up in a bottle like Lucas.
And there is no torque converted drain plug on your A4LD.
JoeOh
I was told by a mechanic that if I have new 4 liters of ATF mix with whats in the torque converter it will cause shifting problems. Is this true? My tranny runs just fine, but I would like to at least have a new filter and clean out the mess on the magnet...
Sasquatch_Ryda
108
Terrace, BC, Canada
Solid Axle Swap 4x4
40s
You will be fine. I'm a technician at a Ford dealership and have never heard of or seen a fluid change causing problems on an automatic trans that is in proper working order. Usually people are bringing them in for some miracle cure when they start shifting bad or slipping and then get pissed when it doesn't fix anything and then have them fail shortly afterward.
If the fluid doesn't smell horribly burnt and it shifts fine you will be fine dropping the pan, changing the filter and topping it back up.
