4.0 ta 2.9 in a 95 ranger
cody93
42
Duluth GA
FORD
the fun beguins, good luck dave!
Ranger Dave
4
Newbury NH
the donor
need to change the Y pipe, VC gaskets, and put the 4.0 flywheel on
then take the y pipe out of the 95 and slide the 2.9 in:yahoo:
Ranger Dave
4
Newbury NH
drivers mount,right on
pass side,had ta get my die grinder out
in:yahoo:
RangerSVT
Oct 09 OTOTM
ASE Certified Tech
53
TRS since 2002 - NW KY
GT-40 5.0L EFI W/AC
Have you thought about using the 4.0 electronics on the 2.9l? Might have to fab a crank sensor mount, but it might solve the wiring issue...
SVT
3,614
SVT
There is no tone ring to run the crank sensor.
Personally, I think he best bet to so research the wiring others have done for wiring the 4.0 into a 2.9 dash and reverse the process.
RangerSVT
Oct 09 OTOTM
ASE Certified Tech
53
GT-40 5.0L EFI W/AC
Iirc, ain't the tone ring on the the crank pulley/balancer? They could be swapped, couldn't they? :dunno:
SVT
Ranger Dave
4
Newbury NH
well, the easy part is done
used a 86/87 Y pipe. also have the converter
3,614
SVT
The tone ring for the 4.0 is part of the balance. I honestly do not know if it will swap onto a 2.9.
mp3deviant721
24
Eau Claire, WI
2.3l of fury
Any updates?
mp3deviant721
24
Eau Claire, WI
2.3l of fury
Well I hope you finish it, I'd love to see it running.
