4.0 Swap into a 94 3.0
Mr. Goodtimes
I'm looking to replace the old 3.0 in my 1994 2WD ranger. I'm doing a pretty detailed restoration of the truck and it's time to do the engine. While the 3.0 runs I want to replace it with a motor that has some more guts. I have some questions:
Engine:
Right now I'm looking at picking up a 4.0 OHV with either low miles or getting one rebuilt. Would this be the easiest way to do things or would it be any harder to install a newer 4.0 SOHC engine?
Does the 4.0 OHV use the same transmission as the 3.0? The people at the local salvage yard have informed me that they are both Mazda transmissions but have different part numbers. So I'm guessing that perhaps it's the same tranny with a different bell housing?
Axle
If going with the 4.0 OHV should I replace the axle that came with the 3.0 or will that be sufficient?
All in all I'd like to get a good understanding as to what I'm in for when it comes to both a 4.0 OHV swap and 4.0 SOHC swap. I'm looking to compare the positives and negatives in order to make my decision.
I don't have the ability to cut and weld stuff so the swap needs to more or less be a drop in ordeal. If it helps any, the purpose of this truck is to turn it back into a nice daily driver. I'm also going to level it and eventually lift it as well as lock the rear in order to do some light off roading.
AllanD
TRS Technical Staff
134
East-Central Pennsylvania
1987... sorta
'93 4.0
Engine:
It would be MUCH harder to swap to a 4.0OHC
The bellhousing is different but since it's cast integral with the case.... There are also internal differences
Axle
The front axle MAY already be the same depending on your axle ratio.
If you have 3.73 gears (axle code 86 or F6) there is nothing to change up front, and while changing out the rear isn't strictly necissary it's probably a real good idea....
The OHC runs on a completely different management system
The 4.0 can basically be swapped in if you get a donor harness froma 1993-94 ranger with your engine.
a 4.0 OHV swap is not too difficult if you get the all the right parts from a Ranger donor vehicle.
the '93-94 4.0 will bolt right onto the exsisting motor mounts so no mount games are necissary.
you will need a Y-Pipe, from a 1993-94 4.0.
AD
Mr. Goodtimes
Allan, thanks a million for the help. Did the 4.0 OHV engines come with an 8.8? If not, will an 8.8 bolt right in or will I need to do modifications?
AllanD
TRS Technical Staff
134
1987... sorta
'93 4.0
Yes, all 4.0 Rangers came with the 8.8" axle.
And yes the 8.8" will bolt right in
BTW when I say "donor harness" I mean start at the big round firewall connector and take every
inch of wire out from under the hood of the donor....
And make sure you get any electronic modules (special attention to the EDIS6 module)
AD
No members online now.
