4.0 OHV to 4.0 SOHV
shadow88
CLOQUET MN
FORD
Has anyone done a right up on going from a OHV to a SOHC 4.0 in a B2? What would this involve?
I can find a number of issues with this idea. First, I am not sure I have ever seen an engine that is not "over head valve". Second, I cannot conceive of a "single valve" engine. I just can't figure out how that would run well.
If you in fact want to swap in a single overhead cam instead of a single overhead valve engine, there are some issues to overcome.
I would get the 4.0 SOHC trans, and a dash swap will probably be needed as the wiring is very very different. There is a thread here somewhere where a guy put a SOHC and a gen4 dash in his 87. It looked awesome. All that info should apply to your swap as well.
8,370
.........First, I am not sure I have ever seen an engine that is not "over head valve"................
My '55 Willy's had a Flat head 6 "Super Hurricane" engine, no OHV.
You are just too young :)
Yes the 4.0l OHV to 4.0l SOH"C" swap would be a complicated swap because the 4.0l SOHC was introduced when Ranger was an inclusive wiring nightmare, got the GEM and also have to deal with PATS anti-theft.
That is the reason you don't see alot of these swaps, other swaps are more practical and can have more power.
If you were swapping a 4.0l SOHC into a 2001+ Ranger with 2.3l or 3.0l then maybe not so bad, but into a B2..............lots and lots of work with little reward at the end.
You would be better off looking at V8 swaps if it is the power you want, been done alot so few surprises.
Oh, and two-strokes have no valves :)
But the piston "acts" as the valve letting exhaust out and new air/fuel in, so maybe it could be consider a one valve engine, admittedly a stretch, lol.
