351w swap headers
noser7
Hey guys I juet have a really quick question. Seems to me like the only difficult part of a 351 vs 302 swap would be jut the headers I think. I wouldn't mind a 302 but a 351 woupd be better torque wise.
So my question is what headers work for a 90 ranger with a 351.
I heard the Shelby tri y fit a the 302 so it would only make sense to keep it easy but if it's possible why not
Thank you in advance
RangerFabWorks
The O.G blackwidow67
715
Lexington, North Carolina
302
Tri-y headers fit with mustang vert mounts. the driverside is close but does fit. passenger side needs the top of the frame notched.
this was on a 90 ranger. 2wd. with a 351. and a m5r2 transmission. using mustang engine mounts.
noser7
Thank you very much sir
I wanted to keep it simple with a 302 but the 351 just seems like it's would be more fun around town stuff. Mpg I don't think should be could be worse with my 2.3 a is the aero on this truck sucks haha
RangerFabWorks
715
302
With a 351w. Depending on your carb and intake. Expect anywhere from 10-13 mpg around town. And 14-17 on the highway. But there's a lot of variables. Transmission. Gears. Tires size. Weight of right foot. :D
noser7
Weight of right foot haha haha
I got a pretty light foot, I just would like to have the option of lighting up the rear tires at will.
Far my truck has 17" mustang wheels with a 3.73 explorer 8.8. As for transmission its either the t5 or a 4r70w trans
Your very helpful bro I really appreciate it.
noser7
This project won't see light til the end of the rear I'm saving money. I just want to avoid bs down the road less head aches
RangerFabWorks
715
302
Your setup sounds good.
Couple of pointers with the 351w
Remove the steering shaft before setting the headers in
After you get the mounts where you want them and drill and slot the crossmember. Boot the mounts to the chassis. And use studs to line up the mounts to the block. Then bolt the engine in
Pass side engine mount is a pain to bolt from underneath. Easier with the engine out
Mount your oil filter relocator to the block before you install the engine. It's super close to the steering box and impossible to try to mount once the engine is bolted in
Other than that. No different than mounting a 302. 351w fits pretty well for the most part
RangerFabWorks
715
302
Here's a few pictures to help you out
The pass side frame was notched from a previous engine. Obviously you can see you wont need to trim that much. But you get the idea.
noser7
Daaamn bro that's clean thank you very much I really appreciate the input. That look looks clean.
Did you have a problem with the side to side movement of the engine hitting the frame or steering shaft? And what radiator did you use?
Besides that I think it's pretty easy.
You should sticky these pictures. I'm sure aloooot of people would like this info, especially where they cut for the headers.
RangerFabWorks
715
302
No side to side movement was not an issue. I only slotted the holes in the crossmember enough to get the engine in.
I use a jegs universal radiator. Size 28x16.5 and modify the core support so it sits inside. Keeps the engine at 180 on a hot day. Well worth the 180.00 bucks
farmer
51
Rochester, NH
Mix of 78-96
Ford donors
357w
Solid Axle Swap 4x4
13ish
39.5x15.5
I did mustang 'vert mounts and the hedman 302 swap headers on my 91 4x4, put the engine closer to the drivers side for passenger side frame clearance and dented in the driverside header to clear the steering shaft rag joint
noser7
Yea that rad looks nice and for the price I won't be able to beat it plus it's aluminum.
I really appreciate it bro honestly this is gonna save me ALOT of headaches down the road.
RangerFabWorks
715
302
No problem bro!
i actually have a few videos on youtube if you would like to see them. i need to update them though.
noser7
For sure bro! What your YouTube name so I can check em out. Thanks
