31 spline 8.8 axle shaft lengths
disciplerocks
July 2011 OTOTM Winner
53
Evansville, IN
I picked up a spare axle shaft a while back thinking both sides were the same. Now I need the opposite side and I am not sure which one I currently have. Anyone know the length of each shaft? The tech library doesn't say anything about the 31 spline shafts.
snoranger
Professional money waster
ASE Certified Tech
13,654
Jackson, NJ
'79,'94,'02,'23
All Fords
2.3 EcoBoost
I found this:
Explorer 8.8 Measurements:
Weight (complete assembly w/ brakes etc.): 174 lb.
O.D. of tubes: 3.250".
Tube thickness: .250" (some are .188”!)
Ring gear diameter: 8.800".
Ring gear bolts: 7/16" dia. (qty. 10).
Pinion diameter/splines: 1.625 / 30.
Axle shaft/splines: 1.320 / 31.
Rotor thickness (where it mounts to axle is .250").
Overall width 59.625" (the F8.8 is .950" narrower then a TJ Dana 35).
(The F-150 8.8 is drum brake and width WMS to WMS is 65.5”.)
Hole diameter for ABS sensor in top of housing: .811".
Bolt size (U-joint flange to yoke) is: 12 x 1.75 x 30 mm
Centerline of housing to C/L of pinion difference is 3.875" toward the P/S.
Pinion offset: P/S to C/L of Pinion, 27-3/4" (no rotor on axle), D/S to C/L of Pinion, 31-5/8" (no rotor on axle). (this measurement is 2.5" more offset to the P/S then a TJ Dana 35).
disciplerocks
53
Evansville, IN
Thanks. Some good info there, just not exacttly what I am looking for.
snoranger
ASE Certified Tech
13,654
Jackson, NJ
'79,'94,'02,'23
All Fords
2.3 EcoBoost
Take a 2nd look:
They should be about 27 3/4" and 31 5/8". But I've also seen the long side listed as 30 5/8" and the short side listed as 27 1/2".
Mac
183
C. Wisconsin
2000
199
That's about what I found, I use RockAuto as a good source also for some sizes.
Dave of the Nord
2000 FORD RANGER 4.0L 245cid V6 FI (X) OHV :
Drivetrain : Axle Shaft Wiki Price
DORMAN Part # 630245 Length: 27 1/4"; Number of Holes: 5; Spline: 28
Includes Bearing, Seal, Studs and Lug Nuts; Rear Right; 28 Spline
$105.79
Add to Cart
DORMAN Part # 630244 Length: 30 1/4; Number of Holes: 5; Spline: 28
Includes Bearing, Seal, Studs and Lug Nuts; Rear Left; 28 Spline
snoranger
ASE Certified Tech
13,654
Jackson, NJ
'79,'94,'02,'23
All Fords
2.3 EcoBoost
Dave of the Nord
$105.79
Add to Cart
The length looks about right.
disciplerocks
53
Evansville, IN
Ok thanks guys. Should be close enough to figure out which side I need.
cstishenko
Kelowna, BC
Thats a good question guys - reviving an old thread.
I have a 31 spline FX4 level II rear end - I am looking for a set of Moser axles. But they need to know the length of axles that I need.
Would those 28 spline lengths be good for me too?
cstishenko
Kelowna, BC
Spoke with every axle mfgr in north america and noone makes an aftermarket axle shaft for the level 2
cdawall
U.S. Military - Active
5
Ellsworth AFB
4.0L V6
Pull the shafts and break out the tape measure. They are the same legth shafts as the 31 spline expo axles AFAIK.
Mac
183
C. Wisconsin
2000
199
Carefull - the Explorer axle is 1 1/2" wider than the '93' and newer Ranger, check tech library.
Dave
Hahnsb2
36
Battle Ground WA
Ford-Dodge
4.0-5.2 Turbo
Dave
We're talking about the 31 spline ranger 8.8.. I'm betting it's explorer width too.
