302 Ranger conversion motor mounts ?
Hagan
08/2013 OTOTM Winner
11
Salem, OR
2.3
Those mounts are NOT bolt on. I just tried them. You have to drill new mount holes and you have to slot the holes.
James Duff has v8 swap motor mounts.
toledo_tommy
Ohio
302
85_Ranger4x4
17,933
SW Iowa
Thanks 85_Ranger . That link was very helpful . So the 1984-1993 Ford MUSTANG 5.0 Convertible Motor Mounts if switched around are a direct bolt up ? Why doesn't everyone use these then ? I just wanna know before I buy anything .
Teddyzee did, I did and dangerranger did. Teddyzee must have done better than danger and I did at slotting it though.
Like this, except I think that is a Mustang:
grips
February 2014 OTOTM
7
Kathu South Africa
ford ranger
347
First used the standard 4.0l mounts but to much engine movement to my liking
Then built my own.
toledo_tommy
Ohio
302
Ahhh I would gladly buy some mounts from you if built more than one ?
lol
Teddyzee
December 2011 STOTM Winner
MTOTM Winner
15
Nova Scotia Canada
5.0L HO, GT40 heads, GT40 intake, 65mm TB, 1.7rr, Tri-Y headers, dual 2.5" exhaust, Flowmaster muffl
A couple more points of interest.
In my reading, typical Mustang mounts have the oil pan sitting close to the crossmember on 4x4 trucks. Not an issue with '83 to '97 2wd Rangers.
Possible ways to remedy this are:
-shim the engine upward slightly (large washer on thew stud between the mount and crossmember)
-the use of Prothane mounts. It's commonly known in the Mustang world that Prothane mounts are slightly taller (3/4") than the vert mounts. (Energy Suspension mounts mimic the height of the lower vert mounts)
Some of the 4x4 guys may be able to add is that much clearance would allow the drain plug to be removed.
BTW, the photo I posted of the cross member slot was from a Mark VII, same idea as the Mustang, same motor mount.
dangerranger83
5.0 HO under the hood!!!
54
Lafayette, IN
If 4x4 and you are ttb, mint the engine up as high as you can to help with the drain plig clearance. Best way is to do the plates mount or use washers. My engine has settled over an inch since my swap over a year ago. Luckily I'm SASed so I cut the ttb mount out of the way.
Sent from my SPH-L710 using Tapatalk
grips
February 2014 OTOTM
7
Kathu South Africa
ford ranger
347
I solved the problem with a Canton oil pan and a purpose build removable cross member .
http://www.therangerstation.com/forums/attachment.php?attachmentid=11103&d=1374000606
No members online now.
