terryduanemiller
- Oct 31, 2010
- Reaction score
- 0
- Location
- Florida/Kentucky
- Make / Model
- Mazda
- Manual
Welcome Visitor! Please take a few seconds and Register for our forum. Even if you don't want to post, you can still 'Like' and react to posts.
my '99 mazda 2wd 5.0 swap. Im using Derale electric fan kit attached to stock rad. I'm using two becool realys and one becool a/c engagement relay.
Awesome looking setup, do you have a part # for your fan kit?my '99 mazda 2wd 5.0 swap. Im using Derale electric fan kit attached to stock rad. I'm using two becool realys and one becool a/c engagement relay.
Hi! I'm thinking of this rad as the option for my 351 clevor build... are you up and running?Ordered the rad today, will pick it up Friday after work. The northern one. NOR205138
$350 Can. after taxes. ouch
will post up pics after it is all installed. thanks for the help guys
I have a low profile flexfan with a pusher efan right now. Works good, if I go slow (busy drive thru) or let it idle the efan will kick on. 90% of the time the efan doesn't run.I see most people going with Derale or fans pulled from junkyard vehicles. I wouldn't trust a Dorman fan myself after having bad experiences with other Dorman parts.
Your results may vary..
I plan on keeping my mechanical fan as long as I can.
GB
It did have A/C at some point but has never had functioning A/C since I got the truck.Was your truck originally equipped with AC?
GB
