300 i 6 swap
fordmandan87
18
Royston, Georgia
Ford×3/Freightl
/5.0/4.0/7.3/DD15
too all of you who have or know someone who has swapped a 300 I6 into their rbv I am looking for any info on all aspectsinvolved in this swap (I KNOW a 302 swap would be easier but this is my choice not yours, boo me if you like)
rusty ol ranger
2.9 Mafia-Don
7,606
Michigan
177 CID
A 3 inch body lift makes things a hell of a lot eaiser.
.....im not sure if the 3 inch body lift will clear up any radiator issues, but radiator clearance may be an issue...maybe run an electric fan?
Other then that its not any different then a 302/351W swap. Just the 300 is an extemely L-O-N-G engine. It uses the same bellhousing and i believe motormounts as the V8.
later,
Dustin
fordmandan87
18
Royston, Georgia
Ford×3/Freightl
/5.0/4.0/7.3/DD15
cool i was planning on runnin an electric fan and to all that reply thanks
fastpakr
2,841
Roanoke, VA
Once you get past the length, it's a pretty reasonable swap. But that's a big thing to get past. The only user I can specifically remember doing this swap ended up cutting the firewall and letting the engine extend well past it.
choped84
milton-freewater, Oregon
3 84's, 1 85
FORD
2.8L / 300 I6
mine dont have a body lift and i didn't cut the firewall. but im running a rear mounted radiator
rusty ol ranger
2.9 Mafia-Don
7,606
Michigan
177 CID
I was looking at doing this swap a while back but i didnt get to involved in it. The 300 will fit without hacking the firewall, if you wanted to keep a front mounted radiator without a lift i think youre looking at either A- Electric Fan or B- Mounting the radiator on the front side of the core support.
If you want i can go measure my 300 I6 in my F150 to give you a general idea of what your looking at.
later,
Dustin
fordmandan87
18
Royston, Georgia
Ford×3/Freightl
/5.0/4.0/7.3/DD15
that would be apreciated and ill go and measure the room in mine. hey chopped how tight is everything in yours
rusty ol ranger
2.9 Mafia-Don
7,606
Michigan
177 CID
Ill measure it tommorrow.
Just got in from ice fishin and now its dark :p
later,
Dustin
choped84
3 84's, 1 85
FORD
2.8L / 300 I6
i dont know how tight it would be with stock front frame rails. mine was totaled in its past life so i just cut off the factory frame from the cab forward.
i took my ac box out so i could push it back a little farther and lower it down more.
the carb was also a little tall so i got a 4bbl intake manifold and am putting throttle body fuel injection on it
fordmandan87
18
Royston, Georgia
Ford×3/Freightl
/5.0/4.0/7.3/DD15
well pictures could help some
choped84
3 84's, 1 85
FORD
2.8L / 300 I6
i'll try to get to my shop to take some, i broke my leg yesterday and it kinda hard to shift.
fordmandan87
18
Royston, Georgia
Ford×3/Freightl
/5.0/4.0/7.3/DD15
any pics yet?
fordmandan87
18
Royston, Georgia
Ford×3/Freightl
/5.0/4.0/7.3/DD15
thanks chopped about how close is your pulley to the core support?
