- Aug 6, 2007
- 1,792
- Macon/Fort Valley, GA
- Ford
- Engine Type
- V8
- 2WD / 4WD
- 4WD
I'm planning to buy the parts to do the swap on my 84 but have a small problem. Over 15 years ago my dad did the DSII conversion on my truck, and threw away all of the stock parts. Now I need to know what I will need of the stock ignition system I will need to make this work.
FWIW the factory engine wiring harness was hacked off at the firewall so none of it is usable, but I'm not afraid of running new wires. I will also be keeping the Offy intake on the motor and using a 2bbl to 4 bbl adapter plate to mount the CFI unit. If I could find the 2bbl upper half for this intake I'd use that over an adapter but I don't believe it can be found anymore.
I will have to get my hands on a TFI distributor, hopefully without buying a new one. Also have to get the TFI coil, but aside from those I don't know what I need. Help!
On the fuel supply could I install an inline fuel pump rather than trying to proceure a 2.9 pump and tank? I will be installing a fuel cell in the bed floor down the road, so buy the 2.9 stuff and throw it out or buy an inline pump and use it with the fuel cell.
