3/4 drop and 18's or 20's?!
jasongind
Parkland, WA
3.0L
first off i did a search and didnt find what i am looking for.
second i posted this in wheels and tires got 20 views as of now and no reponses; most of the guys in there seem to be into offroad stuff so i start it here also.
I just ordered the DJM dream beams and flip kit for my single cab 88 ranger. I was wondering if 18's will fit after the 3"/4" drop, are there any other mods that need to be done to make them fit, and what is the correct backspacing and offset to get? thanks for any info provided.
-Jason
EDIT: I was looking at another 88 with the 3/4 drop sitting on 18's and didnt think the wheels looked that big on it. Can i fit 20's on it with the proper backspace and offset and if so what would it be? thanks again
PFC Laird
UT
352FE
these are 22x9.5 after the same DJM kit drop. and i still have full lock to lock, 20s shouldnt be a problem, although i'm not too familiar with the suspension changes or if your wheel wells are bigger. this is a 94'
rat_ranger
December 2009 STOTM Winner
U.S. Military - Active
MTOTM Winner
moving with the army
2.3 duratec
the problem with the 1st and 2nd gen rangers is the small wheel openings. especially in the front. you have to run a smaller wheel/tire combo than the gen 3+ trucks. so the wheels may not look big but you cant really fit larger and clear the fenders when you turn. i would probably run a small 18 on a gen 1 or2. 20s could work, but you will probably lose some steering radius.
PFC Laird
UT
352FE
k...what he said
jasongind
Parkland, WA
3.0L
or i could possibly modify the front fender well to allow full radius with no rubbing? Im pretty good at cutting. I dont know the correct offset and backspace though. i guess a wheel shop would be able to help me but i was hoping to buy online and mount and balance myself to save $$.
Sunk
125
Everett, WA
3.5 Eco
If you want to cut your fenders, the sky is the limit, but it may look out of place on a lowered truck...
jasongind
Parkland, WA
3.0L
so im guessing if i end up going with a 5/7 later soen the line the 20's would definitely be a no go for that low. looks like ill jsut stick with the 18's, but noone knows the correct backspace/offset for them?
purplehaze
oneida tn
351,gt45 turbo,blow thru
hey, i have 20's on my 90 ranger with a 3 4 drop and also have the v8 engine, so i think it sits a bit lower than 3, you can just roll the inside lip of fender well , and not have any problems of them rubbing, as for backspacing, i ordered a new set of twentys and told them i wanted a 90 ford ranger offset, and they worked perfect with no rubbing and i could go lock to lock.
poopernickle
WESTMINSTER CA
1995 DUAL PLUG
FORD
2.3
hey man, why did you decide to get 22"s, i am thinking of getting 20"?
