3.0 to 4.0 intake swap?
greenbeen89
I was just throng of going a cold air on my 95 3.0 wondered if a 4.0 intake would fit and could then do a spacer or even 02 escape intake anyone know
Detroit
3.0L V6
Someone will correct me if I'm wrong but, I think a 3.0 already has a cold air intake. It sucks the air in through the fender.
mp3deviant721
24
Eau Claire, WI
2.3l of fury
All Rangers already have cold air intakes. A lot of your cold air intakes are actually short ram intakes which suck in warm air from the engine compartment. If you are set on getting an aftermarket intake, get one that actually is routed in a way that actually allows it to suck cold air.
greenbeen89
Sorry should have said upper intake im trying to get little more bottom end out of my 3.0 without groping a 4.6 or a load of cashits just a brain fart after all they only offer us pulley. And programmers for my truck im going to get 4.56 gears in april but always wanting more
mp3deviant721
24
Eau Claire, WI
2.3l of fury
Upper intake does not swap between the two engines. Both engines are in different engine families.
greenbeen89
Was wort a try what would u do? I got 33s and stock everything else look to get little got till I get gears or the motor blows and drop a 4.6 in it but runs really good so going to b a long time for the 4.6 swap
mp3deviant721
24
Eau Claire, WI
2.3l of fury
There isn't much you can do on the cheap. Just wait for your gears. That will make the truck drive better. Unless you can afford supercharging. Tom Morana Racing makes supercharger intake manifolds for the 3.0.
  • Like
Reactions: Mac
Mac
183
C. Wisconsin
2000
199
Yep, I'd sure go gears, about 10K cheaper than swaping in a 4.6 into that year. 5.0L lot better.
The cold air intakes that Ford has now work pretty good, concentrate on other areas.
Dave of the Nord
greenbeen89
What bout a underdrive pulley
Taurus intake. I'm told they breathe a bit better than the ones used on the Ranger.
hoosier1104
I'm Awesome!
MTOTM Winner
104
Camby, IN
302 based goodness
Work hard and play harder
Dave of the Nord
Listen to him. Drop a 5.0 in and be done with it. That is what I did and DO NOT REGRET IT AT ALL! :icon_thumby::icon_hornsup::3gears:
greenbeen89
Aent got the cash and giving it to my daughter in a year so just trying to get little better out of it till I get another to trick out with my son
