3.0 Or 4.0
GRAYGHOST
FORD
I Have A 90 Ranger The 2.9 Was Pulled Before I Got It And Swopped With A 4.0 Or 3.0 How Do I Tell If It Is A 4.0 Or 3.0 Ford Said There Should Be A Tag On The Valve Cover , No Tag
BlackBII
Ranger Custom
Truck of Month
984
UT
What does the Intake manifold look like?
Mutant Pony
9
Hersey, Mi
2300
Does it have a multi coil pack Or a distributor? A pic would be the easiest.
almostclueless
The valve covers extend over the outer part of the intake manifold on a 3.0, much like the FE big block.
In other words, the intake manifold can be taken off of a 4.0 without removing the valve covers.
ZMan
MTOTM Winner
406
Medina, Ohio
Ford Rangers
4/4, bagged
a 3.0l will actually say "3.0l Vulcan" on the black plastic valve cover, thats probably the easiest distinguishing factor on any Ford engine out there heh. If you've got steel valve covers than its definitely a 4.0l.
rickcdewitt
5
nor-cal
4-0 swap
you need to take another look at a 4.0l!:icon_rofl:
Don/TX
Mercedes
Not on my 4.0 either!
almostclueless
OK, fine.
On a 3.0, THE VALVE COVERS ARE BOLTED TO THE INTAKE MANIFOLD AS WELL AS THE HEADS.
