2WD to 4WD
work_in_progress
Has anyone swapped an 89 B2 to 4WD from 2WD with the God awful A4LD and electric shift t-case? If so, how would you wire the electric shift into the transmission harness? Is it already on the wiring of a 2WD B2 or will I need to steal one from a donor truck?
country0001
14
Stillwater, OK
Ford,Ford
4.0,5.0
I've done a Ranger. You can modify the 2wd cross member, but its a pain. The preferred method is to use a 4wd cross member. However, its a bigger pain. The cross members are welded to the frame along with rivets. I've taken one out. It is not fun.
