2nd is messed up in A4LD
texasredneck
FORD
ok so my A4LD i though was shot. but i read Glacier991's thread from one of the exploders forums and changed out my modulator. Well I now have 2nd gear but only manually if its in od or drive it does not shift up. I was wonering if this sounds like a gov. or a shift silenoid? or even a band adjustment. when i shift it manually 2nd gear is strong so i dont think its a band but it maybe.. Thanks in advance.
PS its a 89 broncoII with A4ld and 1354 manual from and exploder.
Bruce
Southwest Missouri
4.0 SOHC
Sounds like governor...But .check vacuum line to modulator to make sure its hooked up and not disconnected on either end and also check to make sure there is vacumm on the line at the mod.
texasredneck
FORD
well i put a new one on today but i'll check out the line later thank you. Oh and i'll check the gov .
2manyfords
Brandon Manitoba Canada
There is a small rod that fits in the modulator, you didn't loose it did you?
If it's missing the tranny will think you are at WOT and shift accordingly.
F150hybred
Arborg Manitoba Canada
That makes sence... in a strange way.
texasredneck
FORD
no I made sure to reinstall that little pin. :icon_thumby:
