2150 flooding bowl
Gravesgrg
Frederick, MD
TVR 280i
I have a 2150 carb. What would cause the fuel bowl to fill and spill out the vent? Was working recently, now it’s possessed
tw205
Bronco II Rancher.
976
Bronson Michigan
Ford Bronco II
2.8 V6
2.8
6” skyjacker 2” body
33x12.5
The port supplying the bowl is governed by a needle attached to a float. If you haven't had it apart and it just started flooding on its own I would think there is an obstruction keeping the needle from seating when the float reaches its set level, or your float has a hole in it, or has detached from its anchor. Are you running the stock fuel pump? An electric pump can supply excessive pressure forcing fuel past the needle and seat.
superj
2,578
corpus christi, texas
ranger edge
3 liters of tire smoking power
none
none
235s
Grew up in the 70s, 80s, and 90s
Though the motorcraft carbs easily handle more pressure than some other carbs.
I agree, unscrew the top cover of the carb and lift it straight up to see if anything is between the needle and seat. You might have to unhook the arm to the choke flap, too
rusty ol ranger
2.9 Mafia-Don
7,502
Michigan
177 CID
Is this a feedback 2150?
Im not real familiar with the feedback ones but isnt there some sort of solenoid on the carb that can cause this too?
The needle valve maybe shot, or the float could be bad (as in, full of fuel and no longer floating)
8,370
And could be the float.............no longer "floats"
