- Apr 8, 2022
- Reaction score
- 0
- Location
- Houston
- Make / Model
- Ranger XLT
- Manual
Hey all, first post to this forum.
I recently picked up a 2006 Ranger XLT, single cab short bed, 2.3L and 5-speed manual. Overall very much enjoying the truck, got a few things done before I register it to my name such as new tires, new windshield, fresh ball joints in the front suspension, small issues like the gauge cluster bulbs being blown out (which I replaced with LEDs), and a nice little head unit upgrade so I can have some modern entertainment features. Great little truck and it's been hauling my motorcycles around to the track like a champ, great gas mileage as well with the 2.3.
Anyways, I have been dealing with some DTCs since I first bought the truck that need to be addressed before it will pass inspection. When I first checked the codes, there were several different codes for the O2 sensor heaters, EGR valve circuit, and evap vent valve. I originally figured it was probably just the O2 sensors that I would need to worry about first, so I ordered those and installed them (both upstream and downstream were replaced with nice Bosch sensors). When I plugged in my scanner after replacing them, the same codes were immediately showing as pending, so I went to the next conclusion that it was something else causing the codes.
Low and behold, I looked up the engine compartment fuse box diagram and noticed fuse 41 controls all three of those circuits (EGR, O2 heaters, and evap vent valve), and sure enough it was blown. I replaced the 15A fuse, cleared the codes again, and for a while (about a week or so) it was fine. No blown fuse, all of the I/M monitors were in ready status after it completed a drive cycle and everything was working smoothly. So I decided to get the inspection done today since everything is in top shape now and it should pass with flying colors.
As soon as I pull into the dealer to get a state inspection done, the fuse blows and the ECM throws all those same codes again. Great, at least I know what the initial cause is, so I replace the fuse again and drive it around the block to get most of the monitors in ready status again and be able to pass. While I was driving around with the scanner plugged in, this time I noticed it only had one pending code, P0452, which is for the evap pressure being low. The fuse did not blow, so the O2 heaters and EGR were in ready status, but evap would not show ready due to the pending code (as well as cat since I only drove it around the block). It ended up failing inspection because of the two monitors in unready status, and during the drive back home the P0452 code stored and threw the light on again. Still no blown fuse, but only one code this time instead of like 10 codes when that fuse 41 blows.
My question is, is it safe to assume the evap vent valve is what's causing the fuse 41 to blow and the DTC? When I research the P0452 code, most of the resolutions point to the pressure sensor in the tank. But that pressure sensor is not controlled by fuse 41, and the fuse blowing tells me that the vent valve is the culprit, possibly being stuck open and making the pressure sensor read low evap pressure.
I ordered a new vent valve, so hopefully that fixes it, but I'm also wondering if there's anything else I should check for? The truck is in great shape overall; it does have quite a bit of miles on the chassis (around 230k) but the engine was replaced at 150k miles and the body, frame, wiring harness, etc. is all in really good shape, no significant rust or corrosion being that it lived in the south its entire life.
