- Oct 17, 2011
- Reaction score
- 12
- Location
- New Joisey
- Make / Model
- Ford
- Engine Size
- 2.9L
- Manual
Seems to start fine and run fine till it gets warmed up then suddenly runs rough and stalls. My guess the issue is when tries to get into closed loop operation.
Prior to this, about 4 days ago I got a CEL and P0174 code, later P0171 as well but it was continuing to run well. I was getting ready to do some diagnosis when new behavior started. Reading I did suggested most likely it was vacuum leak or O2 sensor. I have had the occasional intermittent codes about O2 heater for a few years under harsh conditions that always cleared so was suspicious of O2 sensor.
Just after it started shutting down I was taking a look at how accessable the O2 sensor are and saw the passenger side downstream connector had melted against exhaust. Melted pretty badly. The connections didn't appear as if they open but signals could have shorted against exhaust.
Does it make sense that bad connection to the O2 sensor could cause the symptoms I see when warmed up? if one of the connections shorted (4 wires) to the exhaust, is there a fuse I should check?
Thanks,
Andrea
Thanks,
Andrea
