2001 Ranger 3.0v6 is hard starting mostly when cold.
overseaz
1994 B2300
200
Mazda
I have a 2001 Ranger with 142k miles. I bought it about 8 months ago and pretty much had no other issues.
1. When its cold i have to turn the key over to start and crank it for a good 10-13 seconds and usually have to to that twice, or sometimes 3 times.
It also does this off and on when its warmed up.
2. It also seems to kinda ping when first taking off from 1st gear most of the time, or at least it sounds like a cheap ping/knocking sound.
3. Fuel, on average i seem to be getting 15-16mpg combined city/highway, is this average? I know the gearing is different but my car is a 3.0 gets around 25 average and has twice the performance.
From what I've read here so far it could be the fuel pump or fuel pump relay.
How do you go about checking the fuel pump itself? I know how to check the relays. Or is there anything else i should check for?
Thanks,
Dave
Robin Hood
3.0L V6
I'm not sure about pump location but I'd assume its in the tank.
Sounds like a pump to me, but I'm not sure at the same time, because usually when pumps are bad they wont start at all (at least in my past few experiences).
4x4RangerGuy
5
Newton Highlands, MA
Subaru
2.0
The fuel pump is in the tank on the driver's side. The only way to access it is to take the bed off (easier way, just undo 6 bolts and lift the bed off) or drop the tank by undoing the straps (harder way, since the straps might break from rust).
How's your oil level? Are you losing any? It also sounds like oil may be seeping past the valve seals into the cylinders, causing you to burn off the oil before starting it. Ford Escorts do this all the time. Just keep an eye on your oil level. Are you getting any lifter tap?
Will
514
Gnaw Bone, Indiana
Toyota
If it's hard to start when it's cold, it could be that the engine thinks that it is warm already. I would first check the coolant temperature sensor.
Find the sensor, unplug the connector and then use an ohmeter across the sensor contacts. If the engine is dead cold you should read about 30-60K ohms. If the engine is warmed up you should read about 2-8K ohms.
I don't expect it's the fuel pump. But you can get a pump gauge for $30 at Autozone and screw it into Schrade valve on the fuel rail and know for sure.
Get your codes scanned.
overseaz
1994 B2300
200
Mazda
4x4RangerGuy,
Wow, i sure hope if i put it on ramps that i could take the tank out from underneath, because my truck is loaded full with construction tools. and i have an aluminum utility shell as well, that would be a real pain.
How much do new straps cost of they break?
Yes, actually since the temperature has gotten colder here in california ive been hearing more lifter tap before it warms up.
Will,
I'll check the temp sensor this weekend, that would be cool if that is indeed the issue. I scanned for codes last week and it had no errors and no MIL Light.
Thanks, ill post and update after this weekend.
overseaz
1994 B2300
200
Mazda
So i finally got around to doing a little on my truck.
I gave it a tuneup, new fuel filter, plugs, and cleaned my K&N filter.
At first i thought it helped with the new fuel filter, but no its still hard starting.
Is there any possibility it could be clogged injectors? When its running it doesn't miss or anything. It's just hard starting when cold.
I found an oil leak, it looks like im going to need a new oil pan gasket, up towards the front where the main bearing is, it looks like the pan gasket seal has slipped out, and oil seeps from there, looks like i'll have to keep an eye on it until i change it.
Are there any voltage tests you can do on the fuel pump to test it before replacing?
almostclueless
It's less deceiving to test the fuel pump pressure first. One way or another, the pump requires battery voltage at a few amps to deliver, but there's a regulator on the in-tank assembly that could also be the problem.
If the pressure isn't in spec while idling, then I'd test the voltage to the pump wires as the pump operates, which is a test of the pump itself (possibly shorted), wiring to the pump, relay, and wiring to the PCM.
Unless you have the factory wiring diagrams and understand electronics thoroughly, you may consider getting a 60 dollar dealership diagnostic, as opposed to a diagnostic by billy bob's shop, pepboys (dont get me started), or wherever else.
  • ZMan
