2001 Ford Ranger 4.0 Cat Delete
LivingOnTheEdge
Tampa Bay, Florida
2000
Mercedes-
4.0 V6 SOHC, 4.8TD R4
Ok So I know after reading that there is a few thread write ups on this and I have read them to no understanding. All I understand is this, I have a 2001 Ford Ranger Edge 4.0 with 2 pre cats and 2 cats. In the mass mix up of crap, there is 4 o2 Sensors, 2 upstream (before the precats) and 2 where the cats are.
The issue I am having is this. When I drive my car normally and then shut it off after however long of driving the cats get extremely hot and cause a strange burning smell. I went to a local speed shop, deals with mustangs and such, and the owner told me its the cats that are burning and need to be replaced. So now the problem is, which cats are they? Are they the pre-cats, or the cats? If I can get away with just replacing the pre-cats and then getting an H-Pipe made or even a Y Pipe and then just dumping from the pre-cats into the current exhaust, is that doable without having a check engine light? Is it possible to turn off the down stream o2 sensors with a Flashpaq 1842 or SCT Tuner?
Dirmaid
Louisiana
4.0 SOHC
My 01 only has 3 sensors, 2 before precats and 1 after the last cat. I've got my last sensor turned off for the use of an aftermarket wideband. Sure you can bypass the cats, but I would not recommend it. My main cats are gutted and I freaking hate it. The stench is terrible even with the precats in place. Also since mine are gutted, it flows worse than just a straight pipe and makes a weird airy sound. 0/10 would recommend
Cats don't burn by themselves. Either they failed due to old age or something got into them, fuel or coolant would be the most likely suspects. Either one points to a bigger problem that needs addressed.
  • ZMan
