2000 5.0 Explorer Swap Into 98 Ranger 4.0
Craig0320
225
Mississppi
Break it right the first time. Fix it better the next time.
I really want to put a ranger edge front end on mine. I think they look so good.
SumoPsycho
7
I will be parting out a 2005 Ranger in a few months and I’m going to use the front end and some other parts to make the 2000 look like a 2005.[emoji106]
Craig0320
225
Mississppi
Yeah I like the newer model front ends.
SumoPsycho
7
This is the front end I’ll be putting on my truck, I’ll be adding a new front valance with fog lights too.
Craig0320
225
Mississppi
Do you have to change the core support? Or is it the same?
SumoPsycho
7
It should be the same, but I’m not that far into the swap.
Craig0320
225
Mississppi
Please update me when you get the front end swapped over.
SumoPsycho
7
Will do, that’s going to come after the V8 swap so it my be awhile.
Craig0320
225
Mississppi
I was looking at a new radiator support and it said 98 to 11 is the same part number.
SumoPsycho
7
The older radiator saddle my not have all the correct bolt holes for the newer style front end but the late model saddle will have bolt holes for all previous front ends.
Worst case scenario I will need to drill a few holes, but I think that I can handle that.[emoji4]
Craig0320
225
Mississppi
Yeah I don't think it is going to be that big of deal.
SumoPsycho
7
Yep, I think the engine swap is going to be more trouble.... and it doesn’t seem like that big of a deal.[emoji106]
Jbrown1238
6
Largo, Fl
306
None
I have a 1999 and added the 2011 front end, headlights, grill, bumper, valance, hood, etc. I didn't have to drill a single hole. Everything was a direct fit with the 1999 core support. You do need to add the newer style hood hinges.
SumoPsycho
7
Thank you very much for the info.[emoji4]
Craig0320
225
Mississppi
Great info brother!
