Spitfire1975
- Nov 19, 2009
- 16
- Oregon
- Ford
- Engine Size
- 2.9
This is the first 2wd tranny I have removed. All the others have been 4wd. It's a 1986 ranger with the Mazda.
The question is in regards to the driveshaft. Only one end has bolts. The other end, going into the transmission, does not. Is this a slip yolk that simply slides out of the transmission like the front driveshaft on the 4x4's?
I am assuming it is, but thought I would ask before I dig into it.
While I am at it, what is the best penetrating lubricant to use on the exhaust manifold flange bolts? I usually use PB blaster, but was curious if something would work better on the heat corrosion.
