2 pin plug ID?
alwaysFlOoReD
5,109
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
The following two pics are regarding the same gray 2 pin plug. What's it supposed to hook to? As you can see, someone has covered the end with a red plastic cap. It's located behind the engine above the trans, and the white plug goes to the transmission.
4x4junkie
583
So. Calif (SFV)
Bronco II
2.9L V6
35x12.50R15
I thought that looked like a 4.0L in your pic...
My '94 has that same plug (purple & orange wires, both with yellow stripe). There is nothing connected to it. :dunno:
Edit:
Found the plug on my diagrams... Shows it going to two A4LD shift solenoids. I guess mine dangles empty because I have the M5OD.
alwaysFlOoReD
5,109
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
Thanks.
It is a 4.0l. And it is a m5od.
Next time I'll give all the info....oops.
Good to know it's not needed.
8,371
Yes, my '94 4.0l is a manual and has the same plug but factory cap still covering it, is it for automatic TCC and 3/4shift(OD) solenoids
