2.9l to 2.3l swap
1986fordranger
central VT
2.3l/4.0l
hey guys i have been woundering for a long time how hard it would be if posable to mate a 2.3l 4cyl to a transmission from a truck with a 2.9l , i have herd in another thread it can be done the other way around 2.3l transmission to a 2.9l , thanks for any info
1986fordranger
central VT
2.3l/4.0l
ok what all would have to be done to it to make it fit , thanks for the info
Heavyfire14
19
imperial valley
FORD
2.9L
um. probally motor mounts, and you need the 2.3 harness
1986fordranger
central VT
2.3l/4.0l
should the bellhouseing on the tranny fit or would there be mods haveing to be done to that for it to fit , thanks
kf4lrx
Did you do this conversion? I have a 1988 Ranger Ext Cab 4x4, bith a bogus 2.9l. I want to put a 2.3l in mine.
1986fordranger
central VT
2.3l/4.0l
i have not yet . although i have been gathering parts and information for the conversion . below is some of the information i have come up with
you'll need the 2.3l motor mounts . engine wiring harrness . and the 2.3 computer (behind the passengers side front kick panel) . also
for your year ranger (1988) you either have an a4ld (automatic) or a mazda m50d (manual) transmission
the 2.3 and most of v6s ran different bellhouseing bolt patterns and starter motor locations
if you have the a4ld i believe you can unbolt the bellhouseing and go buy a 2.3l bell houseing and bolt it onto your 2.9 transmission . if im wrong on this someone please chime in
if you have the m50d you have a few more options
(1) you can do like i have done and find a 4cyl 4wd manual transmission from a 1983-1997 ranger and swap the whole transmission out
(2) find a 4cyl 2wd tranny and swap the output shaft and tailhouseing from your 2.9 tranny to the 2.3 tranny
(3) i have yet to find this exact conversion done. but you could find a 2.3 with a 2wd tranny and run a divorced transfer case from a old nissan truck or something simalir to that
hope this helps and if you have anyother questions i'd be glad to answer them
deathstar182
Orem,Utah
FORD
I have heard that the 5.0 bellhousing is the same as the 2.3L could you get the conversion plate and just mount in the 2.3L?
NEALD
The 5.0 bell housing is not the same as the 2.3l. Use a bell housing from a 2.3/a4ld mustang as said above.
I know this is an old thread. I just needed to correct that.:D
