2.9 to 4.0 swap
moto-Leo
Colorado
After a 6 month tour in europe Iam finally home. I swapped the 4.0 in from 92 explorer eb. into my 87 ranger.That was easy.
I have used the wiring harness from the explorer. The Harness is pretty much laid in from the computer all around to the firewall on the driver side. Now what? Is this where the real splicing begins?
1. Do I want to continue with the explorer harness thru the firewall? swap out the fuse block?
2. Do I start picking the wires apart and splice it in?
What will work best? I think I need some advice, Thank You All:icon_confused:
mkpecor
black diamond W.A.
ranger 4x4
at the top of this page click on tech library, scroll down a bit untill you find 4.0 swap, it will be on the left of the page.
rickcdewitt
5
nor-cal
4-0 swap
probably the easiest if wiring is intimidating to you is just swap in the dash from the explorer so you have pretty much an explorer harness
Hahnsb2
36
Battle Ground WA
Ford-Dodge
4.0-5.2 Turbo
The problem is the 2nd gen dash doesn't fit a 1st gen without some good modification which is why I'm keeping the original when I do my swap.
rickcdewitt
5
nor-cal
4-0 swap
it doesn't take much to get the dash hung,its the difference with the explorer heater box that is the hard part.still if you are allergic to wires it might be the easier way
moto-Leo
Colorado
Page 3
explains
"I retained the Alternator wires that come from the drivers side and spliced in the alternator wires that come off the explorer harness"
does this mean the 3 wire plug B/O, Y/W, LT.G/R comming from the fire wall splices into the explorer harness at the big cannon plug downstream of the power distribution box wich is routed to te drivers side.
rickcdewitt
5
nor-cal
4-0 swap
you'll be time ahead by getting factory wiring diagrams for both trucks
moto-Leo
Colorado
After looking at the schems. The ranger had no cruise control and no tilt steering. I kinda like having that stuff. And the power window stuff. I decided to put the exp. dash in and continue with the exp. harness. The heater outlets fit good. Just had to cut off the driverside vent to fit and trim a piece of plastic on the passenger side. Needed to trim some plastic under the area of the speedo stuff. Adjust the tabs on the top side connecting by the wind shield. The dash is in and is solid. 4 hrs work.
rickcdewitt
5
nor-cal
4-0 swap
maybe get some gen2 power doors so the power windows will plug in easy,and a front clip to match?good to see progress
moto-Leo
Colorado
I spotted some power doors at the pick and pull and I will snag them on the weekend.
moto-Leo
Colorado
Fire In The Hole
Jumper her and jumper there. no real cheating. The triple function was a bit of a hang up and a missed groud wire kicked my butt. I guess all the time I spent tweakin on turbine engines and building robots is paying off. This pig is running. Ezra Brooks is tasting real good now. Thank you all for the support and Iamsure more to come. I have a good running 2.9 for someone in need.:3gears:
80351
Valley Alabama
Darn shame we're aren't closer, I could use the 2.9. would make my life alot
simpler.
moto-Leo
Colorado
Truck Runs Well
Truck runs well. I swapped the complete fuel system There was no splicing. It all plugged in like it was in the doner. I only needed to make a couple bends and it all fell in place into the tube holders . to easy.
rickcdewitt
5
nor-cal
4-0 swap
moto-Leo
Colorado
I will do the pics soon. I had to do a meeting thing down in Monterrey Mexico. I do a tremendous ammount of travel with my job and it is hard to juggle the kids , wife , work , and oh my own life. I enjoy TRS and have learned alot of good info. I do feel it is a good thing for me to give back.
Pics and layout should be in a couple days.
The fuel system swap is really simple and I think the explorer setup looks much better than the Ranger set up. I like the stainless hard tubing over the nylon.
