2.9 to 4.0 clutch swap
Broncojumper87
12
wichita Kansas
2.3 EcoBoost
Who has done one? Besides clutch flywheel and starter anything else I need. any particular year to buy parts for aside from just pre 97?
Broncojumper87
12
wichita Kansas
2.3 EcoBoost
I read through that already I was just making sure I didn't need anything else.
Harley
Oregon
Ford bronco 2
2.9
5.5 in susp 2 in body
I'd like to do that swap myself
Broncojumper87
12
wichita Kansas
2.3 EcoBoost
Well my plan is to do the swap this weekend I can let you know how it goes.
NEVERDONE86
Rio Rancho, NM
2.9l
It's pretty strait forward in the tech article. I did it and it works fine. Nothing extra just the clutch, flywheel, and starter are needed
Harley
Oregon
Ford bronco 2
2.9
Ill be watching for your post
jchris36
Olympia, WA
Explorer
2.9L V6
Yeah let us know! I've had this in mind for a while
Broncojumper87
12
wichita Kansas
2.3 EcoBoost
Got the parts ordered last night so hopefully they get here soon.
Broncojumper87
12
wichita Kansas
2.3 EcoBoost
Just a little update got the parts in so far so good. The flywheel clutch and trans are in only issues i am having are not being able to get the cotter key that holds the slave cylinder line back in and finding a gasket that goes in between the trans and tcase. I will most likely just use rtv and call it good.i do have one question though if I use the battery cable from the explorer I don't have to do any other wiring correct?
Broncojumper87
12
wichita Kansas
2.3 EcoBoost
Well here goes a other update not so good news this time. Had to pull the trans back out because my slave started leaking when I started bleeding the clutch master. Anyway got a new slave and hydraulic line today hoping to get it back together tomorrow morning. I have just one more question the new slave came with a bearing does it matter if I use the 4 liter throw out bearing or can I use the one that came on my slave?
The TOBs are the same.
Broncojumper87
12
wichita Kansas
2.3 EcoBoost
Okay physically they look different but I dont want to mess with removing the new one off the slave if they are they same.
