2.5L ('98-'01) 2.5l bearing clearances
Brehenkel
Indiana
2.3l
Does anyone know what the main, rod and crank end play clearances are on a 2.5l SOHC small crank journal engine?
Thanks
Mechrick
68
Las Vegas
Bronco II
Most Ford engines before the Modular family run main/rod bearing clearances around .0008"-.0015". On a performance build for the street, the loose end of that specification is better.
Note, end play is the term for the forward/aft clearance of the crankshaft. That spec is .003"-.008". The above specs are 'bearing clearance'.
Brehenkel
Indiana
2.3l
Thanks for the info.
