2.3L: How much coolant? What flush is best?
arownious
2.3L
Hey guys, trying to flush the coolant today, need to know how much coolant the system + reservoir actually takes.
The previous owner looks to be running nearly straight water in the thing :bawling: and so Im going to go ahead and flush it and possibly run some CLR in it.
Anyone got a radiator flush brand they like?
Edit: I actually just found a lot of bad stuff about CLR and how it is an acid plus how it reacts to aluminum and iron. Yep forget the CLR part. What I did forget to ask however is where the drain plug is for the coolant?
Ranger44
23
Illinois
FORD
4.0 OHV
Drain plug is at the bottom passenger side of the radiator.
I never have ran a "flush" through my system. Just undo the bottom rad hose and flush it out with a garden hose. Better yet, get what's called a flush kit made by prestone. Instruction videos?
http://www.youtube.com/watch?v=_jcjwQXUiiM&feature=channel
http://www.youtube.com/watch?v=tVWznOl-WZw
These are good because they are performed on an RBV.
For coolant, any old green coolant will suffice. If you are mixing your own use distilled water as it has no minerals in it. Minerals are the devil in the automotive cooling system and cause the buildup. Avoid using tap water.
I think 2 gallons will be more than enough.
Bryan22
4
So-Cal babay
94 extd
94 2.3
if it's not overheating don't flush it. i've seen radiators get plugged up too many times from someone trying to flush them. if you do decide to flush it make sure you have enough money for a new radiator. I'm not saying you're deffenitely going to plug it up trying to flush it, but there is a chance.
arownious
2.3L
I'm not sure how flushing it would plug it? Anyways I'm worried about rust in the system as it is. Does flushing not help to remove that and built up crap?
rangerbum
30
Kalispell, Montana
2.8l
If you try to flush it the water or flush could break buildup lose, but force it to settle together in bends of the rad, which will block flow.
Not definitely going to happen, but it is validly possible.
scotts90ranger
4,444
Dayton Oregon
2.3 Turbo
drain is on the drivers side of a 2.3 ranger... take the thermostat housing off and flush it out with your garden hose, the gunk should come out the water pump.
should take about 1.5 gallons if I remember right, I think mine is up to about 2.5 gallons with the large explorer radiator.
pro2am
Acworth GA
2.3
I usually get one gallon of 100% radiator coolant and one gallon of distilled water and blend it to about 50/50. You end up with 2 full gallons, should be enough to fill up your system and the overflow bottle. Check it after a day or two of operation to see if you need to top it off.
