- Jun 2, 2012
- Reaction score
- 8,370
- Location
- canada
- Make / Model
- Ford
- Manual
I thought this was a pre-2004 Ranger build?
2004 was when the instrument clusters changed to HEC and were married to the ECMs, also got SJB(smart junction box), which adds a few extra layers of electrical issues
I think the stand alone EFI would make more sense
The Mustang ECM will have the same issues of being married to the cluster, would need lobotomy plus make it a quadriplegic if it does have traction control software
1995-2003 Ranger has GEM module which is autonomous, and analog cluster
1995-2000 it did control 4WD but if you high jack the 4WD dash lights for the manual transfer case it won't care
2001-2003 GEM didn't do 4WD
If you get a 1997 or older manual transfer case you can use a gear driven VSS on it, for the 8,000ppm needed by speedo, and EFI system, 8,000ppm is the Ford standard pulse per mile
And it can be adjusted for tire size and axle ratios by swapping gears
EDIT:
And haven't looked it up but is the 2.3l Ecoboost a "drive by wire"?
No throttle cable, just adds some cost to a stand alone setup if it is
EDIT:
