2.3 carb help. What are these gizmos?
Dirtman
13,326
41N 75W
It's up there.
It's down there.
Round.
I poop in the furnace.
I'm not ashamed to admit I suck with carbs. This was just dumped on me. It's a pinto but it's a 2.3 so figured you guys would be useful.
The guy says he can get the engine to fire up and idle but it sputters and dies out if you give it any gas. So I'm just giving it a once over before digging into it. Two things pop out right away. 2 gizmos on the carb that aren't connected. First one looks like it was suppose to have 2 coolant lines on it? Second looks like an egr valve on the intake? Wtf are they, what do they do.
ericbphoto
Overlander in development
16,617
Wellford, SC
6"
1. Adjusts idle mix based on radiation level from your dilithium chrystals
2. vacuum operated flux capacitor regulator
sorry. I really don’t know
Dirtman
13,326
41N 75W
It's up there.
It's down there.
Round.
This was as good as my guess! This engine is about as simple as they come and all the basics look good (plugs, wire, timing belt, etc) so I'm fairly certain it's something wrong with this carb.
ericbphoto
16,617
Wellford, SC
6"
I actually like your guess on the get part. The first looks like it’s using coolant temperature and vacuum to adjust something. Might be smog stuff that isn’t really necessary
alwaysFlOoReD
5,109
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
WAG;
1) choke operated by rad fluid instead of exhaust heat riser.
2) manifold vacuum operated egr.
Dirtman
13,326
41N 75W
It's up there.
It's down there.
Round.
WAG;
Was this a serious answer? I cant tell anymore lol....
The thing that looks like an egr doesn't hook to the exhaust in any way, doesn't even have a place to put a pipe from the exhaust manifold? Is there a port in the head or something that routes exhaust to that side?
The choke thing makes sense and could be an issue if its stuck shut and not opening when the engine warms up.
snoranger
Professional money waster
ASE Certified Tech
13,663
Jackson, NJ
'79,'94,'02,'23
All Fords
2.3 EcoBoost
He’s right... it’s an egr valve.
He’s right again... it’s a coolant controlled choke.
IIRC, that choke was only used until ‘77 (but what do I know... I wasn’t even born yet.)
Dirtman
13,326
41N 75W
It's up there.
It's down there.
Round.
Well I'll try and hook the egr up, and see if I can just wire tie the choke open. Its somewhere to start.
alwaysFlOoReD
5,109
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
In a v8 there is a crossover passage between exhaust manifolds that runs thru the intake manifold under the carb mounting. There is a port that taps that passage. The port has mounts for the egr. Sometimes its a plate that sits between the carb and manifold that has the egr port mount, depends on where the crossover is. I used to block the passage when building a engine for racing to try to keep the carb cooler. Sometimes the passage was blocked off with exhaust gas residue.
alwaysFlOoReD
5,109
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
The egr needs vacuum to operate at idle and cruise. WOT it should be off. Pick a vacuum port that does this, I believe manifold vacuum is the one.
Dirtman
13,326
41N 75W
It's up there.
It's down there.
Round.
Yea that's how I was thinking it had to work since theres no pipe/tube connecting to the exhaust manifold. this engine was pieced together so theres no way of knowing if the port is in the head or not. I'm just gonna hook it up and go from there. I'm thinking the choke is probably more to blame here if its constantly at full choke it obviously ain't gonna wanna do anything when you give it gas.
alwaysFlOoReD
5,109
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
Agree on choke
8,371
Try this
Engine key OFF
Open throttle quickly while looking inside the top of carb
You should see gasoline squirt out into the throat, that's the Accelerator pump working
In second picture, the accelerator pump can be seen to the left of EGR valve it is attached to the side of the carb with 4 screws
It has an arm in the center that should be sticking out a bit and its not, thats the pump arm that is pulled in when you open the throttle, and thats what squirts out the gasoline for "acceletration", hence the name accelerator pump
If this is not working then the engine will hesitate and stumble when throttle is opened because the Main Jets can't respond quick enough with the extra fuel needed
ericbphoto
16,617
Wellford, SC
6"
Try this
Engine key OFF
Where do you plug the OBDII scanner into that thing?
Dirtman
13,326
41N 75W
It's up there.
It's down there.
Round.
