1999 Ford Explorer Trans/Clutch Issues
jkufen
Charleston, SC
2.9, 4.0
Well I bought this 1999 Ford Explorer 4x4 for $500 today and was gonna use it as a donor for my B2 but when I got it I saw how great of shape it was in and I think I am going to keep it and wheel it along with the B2. Well the only issue it has is it will you are driving it or sitting still it will randomly make a grinding noise and the engine will rev up. While it is reved up if you try to put it into gear it will make a grinding noise like you are grinding the gears. If you cut the truck off put it into gear and crank it up it will drive fine. Then it will drive fine for a little while and it will act up again. Some times when it does this you can firmly pull the shifter and it will drop into the gear. Any idea what it could be? I will probably replace the clutch but I was curious if there is some other things I could check first like the slave cylinder etc. Thanks for the help!
wildbill23c
Ham Radio Operator
577
Southwestern Idaho
215/70-R14
Transmission syncronizers can cause the transmission to be hard to engage into gear, so can a failing slave cylinder, are you losing any fluid in the reservoir? The whining or grinding noise you are hearing is probably the throwout bearing get that thing replaced before it grenades itself found this out the hard way on a 99 dodge ram which cost me a clutch in the process of the throwout bearing shattering.
jkufen
Charleston, SC
2.9, 4.0
No I am not losing any fluid. When it starts grinding it sounds like there are rocks in the clutch/trans. I figure I'll just replace everything to be on the safe side (clutch, slave and master cylinder, etc). It's not tagged or insured so for the next few months it will be sitting so it's nothing that is has to be fixed today. Thanks for the help.
wildbill23c
Ham Radio Operator
577
Southwestern Idaho
215/70-R14
I'd at least go out and start it once a week and let it run. Could be some clutch parts lose in there you'll find out for sure once you tear into it.
Good find on the explorer though,
jkufen
Charleston, SC
2.9, 4.0
Yeah it was a great find. I can't wait to get into it and get it road worthy! I was excited about my B2 but I am ecstatic about the expo!
