1999 5.0L Mountaineer Build - SAS with Tons
PlumCrazy
2014 Truck of The Year
179
Millersport, OH
Solid Axle Swap 4x4
^My simple axle swap is turning into a nightmare....lol. Basically starting over up front
Sent from my XT907 using Crapatalk
RangerSVT
Oct 09 OTOTM
ASE Certified Tech
53
TRS since 2002 - NW KY
GT-40 5.0L EFI W/AC
The 4406 and 4407 are identical except for the outputs. The 06 is slip, the 07 is flange...
SVT
kris97ranger
36
lisle ontario
4 litre and 7.3 litre
Sounds like you would want the 4407 anyways svt
And plum i know all about the snowball.... my frame and body swap turned into a motor swap propane conversion going from 38.5s to 42s rebuild my freshly rebuilt axles with chromos and now im looking at turbo setups....
PlumCrazy
179
Millersport, OH
Solid Axle Swap 4x4
This high steer idea is going to add more work than I wanted....but I'm committed. I sold my stock stuff.
036speed
02/2013 OTOTM Winner
44
Akron Ohio
F-250
351
Solid Axle Swap 4x4
6"
Kid #2 is due in June. I need to have it mostly together by then. If not, next year.
036speed
44
Akron Ohio
F-250
351
Solid Axle Swap 4x4
6"
SVT
Whoa whoa whoa. So they are both narrower than the 1356!?
This one is out of a 97 F-250.
PlumCrazy
179
Millersport, OH
Solid Axle Swap 4x4
Lol. His search just got easier
036speed
44
Akron Ohio
F-250
351
Solid Axle Swap 4x4
6"
Well, I was invited to a wheelin event at Badlands next weekend. In Indiana. So I bought a cheap unit bearing and threw it on. I am not a UB fan, but it sure is easy. Going to wheel this thing in stock form. Why not.
Check out that shock piston...
My DD gave me trouble today and I dont want to drive it tomorrow. So its either take a day off or try and get my truck out thats been stuck for over 6 weeks. This is the 3rd attempt to get it out. It was 4 degrees out and my driveway is slope that is currently covered in ice. I put my truck in gear and hooked it up to the Mounty. I do not know how, but it DRAGGED my dually 100ft to clear asphalt. One man show. I am very impressed.
The dually was literally iced to the ground.
Here went nothing
I had to keep getting out to adjust the dually's wheel since I was doing this alone.
It earned a heated garage spot for the night. Putting tags on it tomorrow.
escort_gts
02/2012 04/2013 04/2014 OTOTM Winner
16
Fort Wayne, IN
4.0, 5.0
I'm heading out the badlands the 28th of this month
Sent from my SM-N910T using Tapatalk
036speed
44
Akron Ohio
F-250
351
Solid Axle Swap 4x4
6"
No kidding. I am going to a bachelor party on the 14th. We are staying at some house on the property.
Jsommers
michigan
Maybe i should load up my stock explorer and come down and play too.
036speed
44
Akron Ohio
F-250
351
Solid Axle Swap 4x4
6"
Do it. One other stock Cherokee is coming. The other guys are all setup crawlers.
escort_gts
16
Fort Wayne, IN
4.0, 5.0
My ranger is torn apart and probably won't be ready by then, otherwise I would be very tempted to join
Jsommers
michigan
New dual disc in the cummins is still in the break in period and the explorers stuck in a snow pile with a flat tire. I dont see me doing anything until the weather breaks and i can work on stuff easier.
wizkid00104
13
West Newton/Penn Hills, PA
2.3L/5.4L
I'm no expert, but I'd say that shock is just about ready to be replaced.... But the shaft hasn't broken yet. Another 6 months or so and it should be retired. Redneck rule states "if it doesn't move at it should... WD40" lol
Sent from my iPhone
No members online now.
