1998 Explorer t-case awd to manual?
dlevi2121
Brownsville
4.0,5.0
Is it possible to swap out my awd t-case in my 1998 explorer and put the manual transfer in it so it would be 4x4 not AWD?
kozak
British Columbia, Canada
4.0, 351M, 302
In my 97 Explorer, I took out the BW 4405 transfer case and installed a manual BW 1354 transfer case. I had to install a front drive shaft from a 1st gen Explorer to make it work, as well as shorten the splines on the slip shaft an inch or so. The only thing is, I am pretty sure my Check Engine light stays on because of the swap, but that does not bother me, it may bother you. I have daily driven it for close to a year now with no problems.
dlevi2121
Brownsville
4.0,5.0
Well I think I may give that a try any good place to hunt down one of those transfer cases at?
Yellowsplash
U.S. Military - Active
11
Morgantown, WV
You must give some specifics if you want correct answers...If your referring to the explorer in your profile with a v8 then the above information isnt correct. You must specify the engine first...
If your referring to a v6 explorer, then you first must realize that the transfer case isnt awd, but rather a part-time case that transfers power on demand when needed via a clutch.
kozak
4.0, 351M, 302
Sorry, forgot to mention that my 97 has the 4.0 V6. Thanks for catching that Yellowsplash.
dlevi2121
Brownsville
4.0,5.0
Yes mine is the 5.0
Yellowsplash
11
Morgantown, WV
The ideal transfer case would be a 44-06. Go to explorer forums and search 44-06 swap. All the info is there...
dlevi2121
Brownsville
4.0,5.0
