schaffer
- Oct 4, 2010
- 0
- PA
- Ford
- Engine Size
- 4.0
So I've have my 98 for about a year now, a 4.0,4wd,5 speed supercab.I drove it as a daily up until 4 months ago when I got a car for school and used the truck as an offroad toy.I find myself wanting to daily it again.its in great shape still but the front end is out of alignment pretty bad.
Its had a good bit of components replaced on both sides(cv joint,tierod ends,wheels bearing and an upper control arm) but the tires have a large amount of negative camber and the steering is off.
Could the negative camber be caused by the UCA's sliding inward or the torsion bars loosening? I can't think of anything else(to my knowledge) that would cause the tires to pitch the way they are.
As for the steering,can I disconnect the tierod ends,center the wheel and reattach the tierod ends?
One other thing I had trouble with when putting the front end back together was the lower balljoint nut,how tight is tight enough? It seems as if its too loose it will cause premature wear on the ball joint.
I understand a quaility alignment can take care of this,but funds are low at the moment.
