1994 Axle flip ext. cab
dvdswan
2,904
Seattle, WA
Ranger XLT 2WD
What is the driveline rubbing on? Tunnel of the rear of the cab? How did you flip the axle? Did you use spring relocators for the bottom of the axle?
Zmans
57
Delaware
Ranger XLT
I used the axle flip bracket which has a relocation hole that is aimed towards the front offset location. Spring is relocated under the axle. The driveshaft is rubbing under the rear of the cab, I recently swapped the 2 piece over to the aluminum 1 piece from a 99 ext cab 2wd 5 spd ranger.
