1992 Explorer
bronco2fan
10
Copperas Cove, TX.
2.8 V6
2.8
3 inch body lift
So out of curiosity what all suspension and drive train from a 1992 Explorer sport 4x4, 6 Cylinder, manual, 9 inch lift, 35 inch tires will fit on a 84 BII ?
dirtcowboy
5
NW Montana
FORD
2.9, 4.6, 4.0, 6.8, 5.0x4
SenorNoob
576
Middle Tennessee
1.5" Front + 4" Rear
245-70-R16
Just have to grind an re-weld anything that might have been welded to the frame. (Only applies if it's custom work.)
bronco2fan
10
Copperas Cove, TX.
2.8 V6
2.8
3 inch body lift
Ok, I'll have to look real close at it when I go see it. It belongs to a 18 year old who bought it a month ago and can't get it going. Says it has a straight 6 in it too. I thought they all came with 4.0 V6. But if the axles are original and the lift isn't jacked I may get it anyway. I told him I'd give him 500 and he said sure. Figure the axles, lift and rims and tires are worth that much.
country0001
14
Stillwater, OK
Ford,Ford
4.0,5.0
Need pics of the Explorer. 9" of lift sounds funny.
bronco2fan
10
Copperas Cove, TX.
2.8 V6
2.8
3 inch body lift
hope this worked
bronco2fan
10
Copperas Cove, TX.
2.8 V6
2.8
3 inch body lift
Best I could do, on CL in Killeen TX.
SenorNoob
576
Middle Tennessee
245-70-R16
9" isn't hard with a 6" suspension AND a 3" body lift...
That's looks like exactly what they've done here. It just all depends on the quality of the work (and parts used).
If I were gonna use those tires, (and I would by the pics) then I'd only put the suspension lift on the B2 and see where it sits.
