1991 ranger xlt
sly
I recently got a 91 ranger xlt it definatly has some problems 4x4 doesnt seem to work tranny is blown and the 4.0 is leaking like a siv but suprizingly enough it still runs pretty good. i dont mind the work but im definatly lacking in info i know the tannys are apparently weak . does anyone now if theres a different engine and tranny i can put in . or maybe just some advice on the current A4LD and 4.0 im already looking at a total rebuild i thjink not to mention the 4x4 system
dirttrackracer
Law Enforcement
9
Bloomsburg, PA
i wouldnt say weak, they will go over 150000 without problems
feellnfroggy
28
Knoxville, TN
Just do a rebuild, I know you can adjust the thickness of your clutch packs in the direct drive. Not by much, but a lil. A rebuild will be cheapest too. The 4.0l is your best option for engines too, otherwise your just going backwards. Unless you do a v8 swap. THe 4x4 prolly dont work cuz of the electric motor being dirty, follow the cleaning rules in the tech library, takes 20 minutes.
xkotyx
20
Waynesboro, VA
the 4x4 problems are probably related to the electric shift motor.. probably needs a new bushing stopper in there.
mp3deviant721
24
Eau Claire, WI
2.3l of fury
I guess here your chance to put in a manual (M5OD) and a manual shift transfer case. The 4.0 is a good engine, I have one and it leaks oil. But it has 212k on it, so I expect it to leak something. Fix up that engine, it won't let you down.
xkotyx
20
Waynesboro, VA
dont all older engines leak? :icon_twisted::icon_thumby: i thought they were supposed to! mine sure does!
welcome to trs by the way!
mhughes165
9
302
my rangers dont leak, they change there own oil........:D
4.0B2
151
Walls, MS
4.0 v6
Hahahaha lol
Yeah don't consider changing the 4.0, not worth it. It's an awesome motor! And the a4ld is stronger then a lot of propel say. I've beat the crap out of mine with non major problems. From towing stuff to rocks and mud... I've done things im sure ford would probably tell me not to with it
r1hatman
4
Knoxville, TN
2.8
Rebuild or by another 4.0 and as far as the a4ld, swap it for a c5, or even better find a c6 heavy bastard, A4ld is a glorified c3, not that great! Tranny is easy to rebuild, I just rebuilt my c5.
