LilBJessup
- Aug 30, 2016
- Reaction score
- 0
- Location
- Virginia
- Make / Model
- Ranger
- Engine Size
- 2.3L
- Manual
Man did I struggle with the bearings on the 8.8, the 2 jaw puller didn't want to snatch them off. I tried a bearing splitter and could not get a good bite on the bearing. I ended up using a cut off wheel and an air chisel to remove the bearing. Worked like a charm. I think I measured the pinion right and will re-use the stock shims for the pinion and carrier. Also with the 4.56 gears and 32 - 33 inch tires will my speedometer be off. Will I have to change the speedometer gear?
