1987 F-150 Problems
WNY964x4
ASE Master Certified
Firefighter
ASE Certified Tech
9
East Pembroke , NY
Chevy,Ford,BMW
alot of different ones
i have a 87 F-150 4x4 300 6 , C6 Auto and i have the following problems
1. The Speedometer does not work , i replaces the sensor in the axle because it was busted off and still nothing
2. My reverse lights do not work
3. My passenger side door does not open
4. My park lights do not work , to clarify this , My headlights work , turn signals work , brake lights work and my dash lights work when i turn the park lights on , the park lights themselves do not work , front or rear
any help would be greatly apreciated
85_Ranger4x4
17,953
SW Iowa
1. I think on trucks of that vintage, they still have a cable for the speedometer on the transmission/transfer case with the sensor on the axle for the RABS.
2. There should be a switch on the transmission, check to make sure it works. If it doesn't and is getting power like it should you need a new one.
3. ?? Need more info. Could be anything from a disconnected linkage to a dead racoon jammed in the door. You are going to need to pull off the interior door panel to see what isn't working, at least you have the bonus of a working door to see how things are supposed to work.
4. Do all the lights work when the headlights come on? The amber parking lights should be on with the headlights. If they do come on with the headlights, you might try a different switch.
1badexplorer
Firefighter
4
Sutersville Pa
3.0, 501, 7.3psd, 351c, 351w
There is a sensor that goes on the end of the spedo cable right before the trans It only costs about $20 usually it is the problem if the speedo don't work
1badexplorer
Firefighter
4
Sutersville Pa
Oh sorry also, if the door don't open, most likely the latch or handle is rusted or jammed. Also both very common
WNY964x4
Firefighter
ASE Certified Tech
9
East Pembroke , NY
Chevy,Ford,BMW
3. the truck sat for 2 years with the passanger side against a fence and the door was never opened during that time perion
4. no they do not , i installed a different switch because the dash lights were acting up to , the new switch solved the dash lights , not the park lights , and for additional info , i checked the power at the socket , only got 0.07 volts , same coming out of the switch. i know the switch is good because i tested all the lights on the vehicle it came out of before i took them all out
that is what i figured
WNY964x4
Firefighter
ASE Certified Tech
9
East Pembroke , NY
Chevy,Ford,BMW
well i got all the lights fixed , took it for a test drive and she died , so i replaced the relay plugs because the wires were rotted off , still nothing , so i checked the spark coming from the coil , i forgot how that tingles so much , then checked the plug wires , zilch. Took off the distributor cap and the rotor and cap look new , so i think the module is bad. I went to take the module off and could only get one screw out.
any suggestions on how to get the other out ?
