1987 BII 4.0L swap,fuel pump questions
Zero_Cool
Hi quick question for anyone that knows I am going to be swapping a 4.0L from a 92 Ranger and was wondering what PSI the fuel pump needs to be to feed the motor and what will work from the in tank as I will be replacing the in tank on the BII. Any help would be appreciated
ps if it helps I will be replacing all the stock lines with Russell braided lines as my donor one fell apart
alwaysFlOoReD
5,122
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
I bought my b-2 already swapped. They used a pump from a mustang but I don't recall what year etc. I did have the pump assembly out and it looked like they did a little filing to get the assembly to fit where the is a notch for the tank flange. I do believe that you can also just replace the pump with a later year 40psi pump into your original assembly.
Richard
Zero_Cool
thanks for the reply, I also heard that you can use an explorer pump as well if that is true
alwaysFlOoReD
5,122
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
The explorer is on the same basic chassis/running gear as a Ranger/b-2. It's known as an RBV = Ranger Based Vehicle
kunar
131
Toledo, Ohio
5.8l
I have a factory 87 pump feeding my 93 4.0, no issues at all. If the pump is in good shape, it should be able to keep up fine.
