1986 ford ranger 2.3 need info on rebuilding my head
unrevealeddrive
ca
2.3l
i have come to find that head has some issues. first the cam lobes were worn once i removed the cam and rockers i found one of my valves to be ground down almost a 1/4 inch.. and another starting to shop wear. at this point i removed my head.. and took out the valves. the seats look great. my question is i am having problems finding the correct valves and seals. i have the cam and cam followers already i also need new lifter can anyone give me a link to the correct valves... the head has the O shaped intake ports not the D shaped ones incase that helps
tomw
46
lima bean
vertical and above ground
At the top of where you posted is the 'sticky' about the Lima family:
http://www.therangerstation.com/forums/showthread.php?t=9
Search for the word 'valve' and you'll get information that might set you on the right path.
Part numbers for Sealed Power or Federal Mogul or Fel-Pro are given.
What more could you ask??
t
scotts90ranger
4,445
Dayton Oregon
2.3 Turbo
Hopefully you got a roller cam and followers from a junk yard instead of a new flat tappet cam and followers... the roller parts will free up a little power and last forever...
