10 tooth gear on starter
UpStandingMember
upstate New York
2.8L V6
My starter is really loud when I start my truck, and I read that I should change my 9 tooth pinion to a 10 tooth pinion. Well I went to Advanced Auto this morning and no luck there. I've been looking on the internet for three hours and still no luck. But I have seen some Permanent Magnet Gear Reduction (PMGR) starters. So Now I have a couple of questions.
1) Has any one bought a 10 tooth pinion for their starter? If so, do you have a part number of it?
2) Would one of these newer PMGR starters work on my truck? And which one?
My 1983 Ranger has a 2.8L V6 from a 1984 Ranger. My 83 used to have a 2.3L 4banger with a 4 speed manual transmission. It still has the manual transmission, I just changed the engines.
I have shopped for a PMGR starter for a 2.8L motor, but can't find one. I've found some for the 2.0L, 2.3L, 2.5L, 2.9L, 3.0L, and the 4.0L engines.
I would rather just change the gears and keep the same starter in my truck.
Thank you for any help.
Or could I order a gear for the PMGR starter and install it (the gear) on my old Mod II starter?
straycat
77
02 06 and 2012
Jeeps
Check your flywheel for any signs of trouble. Maybe a shim will help it? If it is a starter I would just buy a new one and be done with it. I have never had a starter go out on me before on any cars or trucks.
UpStandingMember
upstate New York
2.8L V6
The starter if fine. It's just loud when I start the truck. I read where after a while, the starter might go out on me because of the gears having 9 teeth instead of 10.
I was thinking it'd kind of suck if I were out some place, and the starter goes out on me. I was just thinking of preventive maintenance.
AllanD
134
East-Central Pennsylvania
1987... sorta
'93 4.0
IF you want a Permenant Magnet, Gear Reduction starter for a 2.8 the one you must use is the one for a 4.0 with an automatic transmission
The one for a 4.0 with a manual trans is different (the flywheel ring gear is closer to the
engine block on a 4.0 manual flywheel)
AD
UpStandingMember
upstate New York
2.8L V6
AD
Thank you, I wasn't sure which one, IF I had to buy one. :icon_thumby:
06RangerXLT
54
Georgetown Ontario
if your starter is grinding on start up, your holding the key too long after it fires.
I had one go out on me just today.
I pulled one in to replace the rad and somewhere between start and finish the starter decided it wanted to die.
holyford86
Some guy with a problem
610
Plattsburgh, NY
many
33x12.50R15
Any good rebuilder should be able to swap your bendix out for the one you need for minimal cost
UpStandingMember
upstate New York
2.8L V6
Yup, thank you. The closest guy I found is in Orwell, Vt. I'm in Ticonderoga. I'll be going over there next week.
Thanks again!
holyford86
610
Plattsburgh, NY
many
33x12.50R15
Thanks again!
well, hello from the other end of the lake, and glad to help.
Kevin Evans
Silverdale, Washington
2.8L
No members online now.
