mobile madness
- Mar 3, 2012
- Reaction score
- 0
- Location
- Virginia
- Make / Model
- Ford Bronco ii
- Engine Size
- 2.9
- Manual
Present trouble fault is code 95. Ive tried to research and see if anyone has had this show up without results. From what the little book tells me its a thermactor code for air diversion only going to the intake. Buuut there is no air pump system on these things. The booklet also said something about fuel. Cant remember, will edit later. Mostle concerned about this fault.
Stored fault is code for low tps voltage. Performed volt test and it checked out ok. .84v at closed throttle. Smooth increase as throttle opens. Ends up around 4.45v at wot. So my best guess is someone has replaced the sensor since the plug is broken on one side.
