I played with the keyswitch (pushed, pulled, up, down, circles) and hit the steering column hard to jar any loose wiring. It had no obvious effect on the way the engine is running. Let me know it there is something else to check.
All symptoms I started this thread with are still present (stumble on snap to WOT, random misfire, rough running, backfire out the exhaust) with one additional (high idle, IAC slowly reduces idle when closing, it has bumped the idle to the rev limiter) and the backfire is back. The truck sat in the garage for 5 days undisturbed.
The Actron scanner tool I rented from Autozone broke so I took it back. Looking for a good bi-directional tool (anybody know any good ones?), but will be awhile before I can afford to get one.
I have previously discounted a major vacuum leak because the MAF showed corresponding increase when the idle went up. Additionally, if a leak were present to idle up to the rev limiter, I am assuming the engine would stall with that much unmetered air. LTFT1/2 have always been positive and at there highest less than 10% and usually within 2-3% of each other. STFT has been +/- at about the same rate as the O2 sensors. I don't have a scanner with live data anymore so I cannot check anything else.
I am diagnosing this as a PCM problem (with possible addition of fuel pump or regulator) because there is not a short in the control voltage for the IAC that I can find. Either a bad IAC (just replaced), short in the signal wire, or a short in the power wire will cause this (not limited to these). I was limited on the testing I could do according to the PC/ED manual because I could not access all the PID's (specifically IAC duty cycle) with the Actron, and I do not have access to an oscilloscope (nor the money to invest in one).
