02 ranger 4x4 FX4 off road rear disc brake conversion
2ndSS
10
Illinois
31" on the 02 FX4
ok so I am reading in the tECH lIBRARY REAR DISC BRAKE CONVERSIONS, AND IT SAYS the mustang kit works but not on an 02 4x4 FX4. I would like to know why? is it the shock mount placement? please
pjtoledo
2,995
Toledo Ohio
Fords
3.0 2.3
the outer axle ends are bigger, which means the backing plate has to be bigger.
assuming 31 spline unit, regular Rangers had only 28 spline axles.
rubydist
865
Denver
Ford Ranger FX4
The 02 FX4 should have come from the factory with the 31 spline rear axle. If it still has that, the Mustang rear disc brakes will not fit. In 03+ the FX4 Level II only had the 31 spline axle. After they dropped "Level II" then the 31 spline axle was an option through 2009. After that, they are all 28 spline axles. The Mustang rear brakes only fit the 28 spline axles.
There is a Ford Performance disc brake kit for the Ford 9" axle that does fit the 31 spline axle. I have that on my 09 with the Torsen diff axle. So, if you can find one of those, you can still install disc brakes on your 31 spline axle.
2ndSS
10
Illinois
31" on the 02 FX4
ok, thank you so much guys for your replies
Kirby N.
Truck of Month
78
Monument, CO
97-200X explorer disks should work. I swapped them on my drum 1993 31 spline explorer rear end- straight bolt in swap.
