02 FX4 Twin stick Build
02Fx4red
Rebuilt the bronco steering box
Did 700km hauling close to 3000lb
I love the snow
MagicMexican
Great progress, man! Looks amazing and very capable.
Do you have plans to upgrade the SOHC to a V8?
02Fx4red
Thanks, no plans at all for an engine swap. With 5;13 gears and 37s the 4.0 will have plenty of power for what I need. And if I were to do an engine swap I don't think it would be a v8.
Keegan Kael
Carp, Ontario
Since you live in an area that deals with Ontario's stupid etest regulations you can't actually swap a V8 into your truck anyways. Anything newer than 99 in our area is almost impossible to swap in a bigger motor, found out the hard way with my 03 Mustang.
How much body lift are you running to be able to clear those 35s?
02Fx4red
There are ways, but it's not easy, and you have to do things a certain way. a real pain in the ass. And I've seen guys with v8 Rangers and There is a guy here that has a 4bt Cummins in his 08 ranger.
If I were to swap a different engine it would be a 4bt, but I don't see that happening.
It's just a 3" performance accessories body lift. I also have explorer leafs with add a leaf and lift shackles with stock block removed.
And 2" torsion bar crank.
02Fx4red
More parts
Power steering cooler, e250 steering shaft and a double cardon driveshaft from the wreck yard.
IMG]
One ton tie rod ends with 1.5" .250 wall Dom tube for tie rods and drag Link, Johnny joints for radius arms
37s!
gw33gp
538
Costa Mesa, CA
4.0 SOHC
33"
I run 33 inch tires with only a 1.5 inch tbar crank. It helps that the tires are only 10.5 inches wide.
02Fx4red
Welded the radius arms
Unbolted all the ifs, now time to start cutting stuff off the frame
02Fx4red
Installed the new transfer case, plated the frame, started building a crossmember for the radius arms, still have to add some gussets and finish welding it.
Bunch of pics
Ford78
December 2012 OTOTM
Iowa
351w
Great progress!! Can't wait to see it done
02Fx4red
Finished the radius arm crossmember
Tube rear crossmember to replace the stock tire carrier
Chevy 64" leafs with new bushings, cut overload and one ranger leaf added.
Rear end is in, just have to set pinion angle and weld on perches and then do shocks
02Fx4red
Sitting on its own weight with a ratchet strap for a trac bar, I like the height it will sit at
Made some heavy duty lower coil mounts, couldn't get the coils to sit how I wanted with the stock bronco ones
Shortened e250 steering shaft with a pillow block bearing attached to the firewall
Dom tube through the frame for the steering box
02Fx4red
Front end is getting there,
Plan to mount the shock to this
02Fx4red
Fox 2.0 shocks and limit straps from TMR customs.
Shocks, bump stops and limit straps are tacked in, front is pretty much figured out, just have to make a front engine crossmember and finish welding all the links and brackets. Then onto the rear.
