02 Ford Ranger 3.0 auto 2wd sputters and stall and now won't start
Redline4x4
2002
02 Ranger 3.0 sputters and stall and now won't start
I have a 2002 Ford ranger 3.0 auto that had a starting problem where it would sputter and stall randomly with cold starts. Sometimes just once and recently had been a pain in the a** to start taking 5 mins or more. And finally now it won't start. I replace the fuel filter recently when it was intermittent to try to stop it. It has new plugs and wires and I swap a coil from a running truck on to see if t was the coil. Iv tried 3 fuel pump relays and all seem to work properly. The truck has fuel
Pressure at the shlader valve on the fuel rail but I don't have a fuel pressure gauge, I intend on getting one to test it soon but it seems if it was getting fuel it would at least sputter now it does nothing but cranks. No check engine lights at all. Any help is greatly appreciated! Thanks!
8,372
Do a 50/50 test
Spray gasoline or Quick Start(ether) into the intake and then try to start engine
If engine starts up and dies then fuel is the problem
If engine doesn't start then spark is the problem
50/50
From description of symptoms it is probably fuel pump
You should hear the fuel pump start and run for 2 seconds each time key is turned from off to on, it is not quiet
Repeat key off and on as much as you want it won't hurt anything, and listen for the pump each time.
Fuel pump is just an electric motor, it can start to spin slower, so less pressure, and start and stop randomly
Redline4x4
2002
Do a 50/50 test
50/50
I hear the fuel pump make noise almost everytime I turn the key. I got a fuel pressure tester gauge so I'm guna try the fuel or starter fluid in the intake and check the fuel pressure. Il get back to you thanks for the advice
8,372
The "almost" is not good
2002 fuel pressure should be 65psi with engine running, 60-70psi range
And drop no lower than 50psi with engine/key off for 10minutes
Engine running fuel pressure should be steady, no changing up and down
