Introduction
This article is about the Ford 4.0L OHV engine used in the Ford Ranger from 1990-2000. For the 2001-2011 Ford 4.0L SOHC engine check out:
Ford Ranger 4.0L SOHC Engine
The Answer To The 2.9L Problems
The 4.0L OHV (Over Head Valve) V-6 engine found its way into the Ford Ranger in 1990 and ultimately replaced the 2.9L V-6. This evolutionary redesign of the American 2.9L solved many of the reliability issues that plagued its predecessor. A beefier cylinder head design eliminated the 2.9L’s common failure of cracked heads. Hydraulic roller lifters replaced the simple hydraulic lifters used in the 2.9L, which were sometimes overly sensitive to oil contamination, often requiring the lifters to be replaced prematurely. However, one major design fault was not completely eliminated: Valve rockers and upper pushrod tips still received poor oil supply, resulting in eventual wear to these areas, and consequential valvetrain noise as a result of the increased clearance. Required replacement of these parts is common in older engines.
The 4.0L OHV engine was produced until 2000 and was used in the Ford Explorer and Ranger. Output was 160 horsepower and 225 ft·lb torque. Though there is some variation, typically 155hp is quoted as horsepower for 1990-1992 applications.
In 2001 the 4.0L SOHC (Single Over Head Cam) engine replaced the 4.0L OHV engine producing 207hp.
SOHC & OHV Engine Differences
The difference between a SOHC 4.0L and OHV 4.0L is that in a SOHC engine there is a camshaft sitting on the top of each cylinder head with the valves running directly off the camshaft. It doesn’t rely on push rods, rocker arms, or lifters. The SOHC engine uses a jackshaft in place of a camshaft to drive a timing chain to each cylinder head. Three timing chains are used, one from the crank to the jackshaft, one in the front of the engine to drive the cam for the left bank, and one on the back of the engine to drive the cam for the right bank.
The OHV engine has the cam mounted above the crank. The cam and crank are joined in time by a timing chain. Lifters ride on the cam and push rods that extend to rocker arms in the heads which push the valves.
The SOHC 4.0 Usage
The Ford Ranger switched from the OHV 4.0L to the SOHC 4.0L in 2001. The Ford Explorer actually started using the SOHC 4.0L in 1997 along with the OHV 4.0L. It wasn’t until 2001 that Ford completely dropped the use of the OHV 4.0L in the Explorer.
For more information on the 4.0L SOHC engine visit:
Specifications
Engine Displacement (Cubic Inches) 245 CID
Type OHV
Bore x Stroke 3.95 x 3.31 inches
Compression Ratio 9.0:1
Fuel System Sequential Fuel Injection
Fuel Pressure 39 – 40 PSI (30 PSI @ idle)
Horsepower 160 hp @ 4200 RPM
Torque 220 @ 2400 RPM
Oil Pressure 40 – 60 PSI @ 2000 RPM
Tune Up
Spark Plug (Motorcraft)Important Note: The SOHC spark plug is about 1/4 inch longer than that of the OHV. The OHV plug will fit but it won’t operate properly.
(OHV spark plug at the top – SOHC plug on the bottom)
1990-1996 uses SP486 (Platinum)  (old part number is AWSF42P)
1997-2000 uses SP500 (Platinum) (old part number is AGSF22PP) or SP413 (Premium Nickel)
Spark Plug Gap 0.054 inches
Ignition Timing 10 degrees BTDC
Firing Order 1-4-2-5-3-6
Capacities
Oil Capacity With Filter Change 5 Quarts
Cooling System Capacity (Quarts) W/AC- 7.2 / W/O AC 6.5
Torque Specifications
Cylinder Head Torque in 3 steps [1st (22-26ft-lbs), 2nd (52-56ft-lbs), 3rd (Tighten another 90-degrees)]
Main Bearing Bolts 66 – 77 ft-lbs
Rod Bearing Bolts 19 – 24 ft-lbs
Crankshaft Pulley Bolts Torque in 2 steps [1st (30-37ft-lbs), 2nd (Tighten another 90-degrees)]
Flywheel to Crankshaft Bolts 59 ft-lbs
Lower Intake Manifold / Throttle Body Torque in 4 steps [1st (3-6ft-lbs), 2nd (6-11ft-lbs), 3rd (11-15ft-lbs) 4th (15-18ft-lbs)] (OHV Engines)
Exhaust Manifold 19 ft-lbs
Ford Ranger 4.0L OHV V6
4.0L Firing Order:
4.0L Engines Firing Order: 1-4-2-5-3-6 DIS Ignition System
Forum Link
4.0 Liter Forum | The Ranger Station
Related Articles
Rebuilding And Improving A Ford 4.0 Engine
How To Build A Ford 4.0L For Power
Ford 4.0 OHV Tuning Tricks
How To Build And Modify Ford V-6 Engines (.pdf)
Loose Ford 4.0L Intake Bolts
Ford 4.0L Camshaft Synchronizer
Ford Camshaft Position Sensor (CMP) / 3.0L, 4.0L & 5.0L
Supercharging A Ford Ranger 4.0 OHV V6
4.0 Liter Engine Conversion FAQ’s
4.0 OHV to 4.0 SOHC V6 Engine Swap
Last Updated:
About The Author
